Does a Lithium Battery work in a 2008 GS? What Lithium Battery did you use?
Hello all! I put a lithium battery in my Yamaha and love it! Now, my 2008 GS Spyder is showing low cranking voltage, so I would like to put a lithium in it, but want to be sure it is compatible, not everything is. So, have any of you with a 2008 put a lithium in your ride, how does it do, what battery did you use, please? Thanks.
I have a lithium battery in my 2023 Spyder and love it. It turns the engine over without any hesitation at all. The factory battery gave up after about 6 months. The lithium has been in Spyder for 26 months now without any problems. I picked mine up at Lamonster Garage:
12V 600A Lithium Powersport Battery (NLP20) (600CCA)
I don't see why it would not work well in your 2008 GS Spyder.
Of course, a lithium battery will work on your Spyder. Just get a good one. There are several out there that do a fine job.
The trick is to find one with a built in BMS, and also use only lithium specific maintainers if you're going to let the bike sit. A good lithium brand is Antigravity with the Restart feature. Get one that exceeds the CCA of the stock battery. I use a 480 CCA one. They're not too expensive as lithium batteries go and they'll turn the starter over like nobody's business, thanks to the high voltage an CCA.
Thank you all for your replies, I appreciate the feedback! Looking around 500cca. And I have a lithium capable maintainer already. Many thanks!
Glad that Spyderlovers Forum was able to help you.
So tell us about the battery you purchased. Always ready for a new take on the 'Lithium Batteries'.
Thanks for your time. (y)
