Educate me on the reliability of the Rykers
RykTek
Now that you have educated me a bit on the older RS models, maybe you can tell me about the Rykers?
Again, I was looking at the Rykers and reading about the VSS codes that put you into limp mode for no reason made me real nervous.
Like I said in my other thread,
I am a DIY person. No dealerships for me. The Ryker seemed a lot easier to work on in general compared to the Spyders. It is a lot more like a scooter, which I have experience working on.
How dependable are they. Easy to work on? Do they throw a VSS code every time you look at them crosseyed?
Which would you go for - an older ('09" RS) or a newer Ryker Rally?
THANK YOU!
The Ryker is a dependable ride. And they are easier to work on than the Spyder. The biggest maintenance item is the drive belt which BRP recommends to replace around 10k. Many get more miles than this out of it. But it depends on how the belt was broken in and how the Ryker is ridden. Putting a free flowing air filter on the belt drive side (like K&N) will extend the life of the belt. Still, it is a good idea to check that filter often.
Bought my 2022 Sport in 2023 so I don't have a lot of miles on it.
But it has never thrown a VSS fault yet.
My understanding they don't like trail braking (holding the throttle open and braking at the same time.)
The manual says not to use the cruise control in the rain (wheel spin, the TC is trying to brake and the cruise is trying to speed up)
Pretty simple to work on, and Rotax builds strong motors. There are sleds and side by sides that use the same basic motor pulling a lot more HP (200 plus)
One member here rode hers to Alaska and back.
Hope this helps
Bruce
I owned a Ryker for three years and follow the groups. My impression is Rykers are less reliable. Yes, many people have had no problems, but VSS faults, yaw sensor, the so-called "left turn wobble", and fuel pump issues are common. My Ryker was the most unreliable motorcycle I have ever owned. My 2019, bought used with 2500 miles two years old, had
  • A broken roller on the driven pulley almost immediately.
  • A botched fix (which the dealer did promptly correct) that left me stranded 20 miles from the dealer.
  • Very early nanny on left turns only ("left turn wobble". The dealer charged me $170 to say it was "normal". At that point I bought my own BUDS and did fixes myself. The nanny fix required a Steering Update Kit per a Service Bulletin on this (which the dealer ignored when I pointed it out) and replacing a bad SAS.
  • 2 fuel pump failures, one I caught and fixed before getting stranded; the other left me stranded.
  • Fuel pump whine necessitating a Service Bulletin fix ($6 part added to the fuel pump, not covered under a recall).
  • A failed exhaust manifold gasket (also not uncommon).
  • Wheel nut recall and fender wiring recall. There was also a fuel pump recall for which I was told I did not qualify and other recalls that did not affect mine including a loose handlebar fix.
  • Cracked front wheel (I did not hit anything).
As mentioned, the belt needs changing or at least inspection at about 12k miles; you need a special $30 tool to do it and BUDS to reset the service reminder if having that reminder constantly pop up bothers you.
  • Very early nanny on left turns only ("left turn wobble". The dealer charged me $170 to say it was "normal". At that point I bought a BUDS and did fixes myself. The nanny fix required a Steering Update Kit per a Service Bulletin on this (which the dealer ignored when I pointed it out) and replacing a bad SAS.
Yikes! Thanks for the heads-up. Good to know.
All good info, both here and in your other thread, but please, do remember that Forums like this is where people come to find info about and resolve problems... So for every person you see/hear on any Forum with an issue, there's likely at least 15 or more people out there who are just riding on with absofreakinlutely NO concerns at all and without ever having had any significant issues either, except maybe due to the 'poor customer service/knowledge of some dealers, and those 'Great idea, absolutely crappy execution' issues that BRP still insists on foisting off on us & never bothers to fix!! :cautious:
So as a Spyder Rider for over a decade now, having ridden well over 'just' into 6 figures of miles total on various Spyder's & Ryker's, I reckon you should probably forget about making such an effort to get all the bad news about all the potential problems that might occur, which in reality, a relative 'few' owners have encountered and most only ever read about, seemingly in an effort scare yourself AWAY from these things; and instead, go ride one or as many as you can!! (y)
Maybe you should do one of the Demo rides that @cptjam is involved with running every year -
Or try to get on one of the MFS Courses for new Spyder/Ryker riders that are often run in various places over your way...
But above all, try them, ride them, and find out if you can enjoy the ride (bearing in mind that it takes many a while/a few thousand miles to truly come to grips with the different experience) and if you think you could come to like it as much as the rest of us do, then just:
'Buy the Damn Bike! You KNOW you Want to!'
And from there, ride it, learn about it, enjoy it, don't sweat the small stuff, just enjoy, and:
'Ride More, Worry Less!' ;)
Just Sayin' 😊
Not to dispute the seriousness of your situation. But the fact is that you can go to any forum, Goldwing, Harley, you name it and find similar stories. Every product has it's issues. The seriousness and repetition may vary. And I think that is the question we are looking at here.
I'm not trying to talk myself out of one. I am just a research-heavy type of person. At the same time I am looking at Spyders/Rykers, I am looking at Harleys, BMWs and a few Jap bikes. In fact, I never STOP shopping.
I have been able to keep myself in "free" motorcycles for years now. Buy low, have fun, sell for a few bucks extra and move on.
I DO want a Can-Am! Hard to decide if I should pursue the '09 RS Spyder or a newer Ryker though. I have to admit, the RS is SOOOOO purty....
Yep. I wanted a Gold Wing 1500, so I spent a good while researching them. By the time I found a "deal" on one I already knew enough about it to rebuild it. So that's why I do my research.
If it's built by man, it will fail and break down sooner or later! It comes with a warranty and hopefully the design failures will rear their ugly heads before it runs out! You said you are a DYI type of person and trust me you are not going to find anything in the world that will last forever without working on something! Just bite the bullet and put your hair in the breeze and buy one, you know you want one, get it!!! Stop trying to talk yourself out of it!!
I follow both Spyder and Ryker groups. While my personal Ryker experience is admittedly not common, I also indicated that VSS faults, yaw sensor failures, the so-called "left turn wobble", and fuel pump issues are commonly reported. I have seen more posts on VSS problems and limp home mode with Rykers than Spyders, and also specific Ryker design defects related to VSS and design and manufacturing defects with the fuel pump that were not covered under recall or warranty but in my opinion should have been.
To answer the OP's question directly, I would choose an older Spyder over a newer Ryker. In fact I did.
l had a '20 Ryker for 4 months, had 2 VSS fault codes on it, put in a little over 1000 into it before l traded it for my F3 SE. The Ryker was in the shop getting fixed the 2nd time when the finance guy said, let's get you into a new ride. l had only made 4 payments on the Ryker. l love my Spyder, he has way more power. The Ryker always sounded like I was pushing it to its limit, but my F3 just cruises along perfectly. Look into a Spyder before you get a Ryker, you'll love it!
2023 Ryker Rally purchased new. 3,400 +/- miles, most put on last year. No issues, though it did have a dead battery when I picked it up from the dealer. Prepping for another 3,000 mile trip.
I have a 2019 Ryker 900, purchased used with 2100 miles. I do my own maintenance and find it is easy to work on. It now has 18,000 miles and the only VSS code it has thrown is when I got some old gas. I've done the belt, all the fluid changes, a rear tire, and added a couple of "extras" without difficulty. I have no interest in a Spyder, as I like the raw look/feel of the Ryker. Are there "Monday" machines out there - of course, but mine has proven reliable and fun.
I've had my Ryker since March of 2019 with no issues. I hate even saying that for fear of jinxing myself, but there it is. Granted, I don't ride it as much as I'd like but it is what it is. I'm thinking this may be the year that I finally put a new battery in it though.
The reason your Ryker sounded like you were 'pushing it to its limit' is because it has a CVT (Transmission). This design keeps the motor at optimum RPM within the power curve. This makes a smaller engine perform like a much bigger one.
I've not ridden the 600 cc version. But our 900, while not putting out the HP of the 1330cc Spyder, is impressively quick. We actually loaned it to a customer who brought in their 1330 RT for service. He wanted to go get lunch, so we let him ride our Ryker. When he got back, we asked him what he thought of it.
He said he didn't like it at all. When we asked 'why?', he said it was way too fast for him.
It is true that the Ryker model has suffered some overly frequent issues. The yaw sensor and fuel pump being 2 of these. But the only issue we have had with our 2019 was an oil leak from a shaft seal which was repaired on warranty and hasn't been a problem since.
