BajaRon
Well-known member
You are not only heavier than the average rider the Ryker was designed for, but taller, which is also a factor. I would definitely try one more notch on the front shocks just to see if that helps. You can always turn them back down if needed. I'd also try 20 psi in the front tires. Again, if you don't like it, set them back down. These are free 'Mods' and easily reversible.
Not to knock anyone's products. But the BRP upgrade sway bar is very weak. One reason is that they can't go too far without the danger of breaking the composite plastic end links. With your weight and height, a heavier sway bar would definitely make a big difference.
The steering damper was a good move.
Off road, or very bumpy roads, anything will tend to 'Hunt'. Generally, you should limit your efforts to correct for this because the machine will naturally try to come back on its own. If both of you trying to compensate, you may over correct and make things worse. I'm not there so I can't say if this is part of your problem. Just throwing it out there.
As Peter says, try to relax and let the machine do what it does best and only add input if needed. Once you get the hang of it, you'll have much more confidence in the machine and things will improve greatly.
