IdahoMtnSpyder
Well-known member
I'm thinking that the low voltage of the battery may have caused the cluster and/or ECM to get confused as evidenced by the screen acting oddly. Disconnecting the battery and letting the bike sit for a minute or two should give the computers a chance to reboot cleanly when you connect a good battery as recommended above.
There is quite a bit of discussion on here about batteries but generally speaking you will be well advised to go with a Yuasa like the OEM unless you're inclined to spend extra for something like an Optima, which I'm not sure gives a return worth the investment. In any case don't waste your money on a cheapie from Wally World, or the like.
