Electronic Cruise Control ?
ulflyer
Well-known member
I've had two RT's and various other vehicles, all with electronic cruise controls. Due to physical limitations its something that I make a lot of use of.
Is that available for the Ryker?
I know about throttle locks and they don't cut it for me.
Thanks Anne. I didn't think so either, but since I can't swing my legs over the RT, and not easily on F3, I've been thinking about the smaller 900. Can't live without CT tho. ha
You can always go to an aftermarket CC. I've done it and they work very well. Get the electric, not the vacuum powered model. My only issue is that the control head, being designed for inside a car, does not hold up well in the rain. I have not found a solution for this issue.
Ron, thanks for that info. Didn't even know such devices existed. Looked at couple online and can see that the installation is far beyond my skills and I don't know of anyone around that I'd trust to tackle it. :)
They aren't that bad to install. Finding room and a good place to mount the components can be a bit of a chore. But if it is beyond your skill set, it would be better if you could find someone to do the install for you.
