I dunno pauly, the ACS on our Spyders doesn't really qualify as an '
air shock' on any count!! :lecturef_smilie:
It's more of a '
ride height adjusting' system that uses variable pressure in an air bag that's completely separate to the coil spring/shock assy in order to maintain the ride height under varying loads....
The up-market models get the 'automatic system' which adjusts the air bag pressure to maintain a preset ride height that requires BUDS to vary & which is pretty prone to failures, hence why many by-pass the auto bits completely & manually set their choice of air pressure & therefore ride height; while the 'lesser models' get a manual system effectively does the same thing, ie. allows the operator to adjust the air pressure in the bag & therefore adjust the static ride height themselves! :clap:
Altho with that understood, the coil spring & shock assy's on Spyders with either system are basically
juuust capable of holding the rear of the Spyder off the tire by themselves under a relatively light & usually solo operator load, so unless the shock/coil assy has been upgraded, the air bag
WILL be necessary & need
some air in it if you are carrying any sort of load on your Spyder, or it'll either bottom out intermittently &/or possibly continuously drag its bum on the tire!! :gaah:
So really, the ACS, either manually adjusted or automatically, doesn't increase the load capacity of your Spyder at all - it just allows you to maintain or possibly adjust the loaded ride height while the shock/coil assy does all the real load carrying and suspension tasks! And if you get a Spyder with the 'automatic' ACS, not only do you get no real choice in that ride height, be prepared for compressor failures &/or leaks! These failures/leaks might not happen over-night or even immediately, but give it a while, they
WILL happen! :banghead: . And when they do, you can chase around throwing good money after bad trying to fix it for the long term rather than band-aid it for a short while, but eventually, you'll most likely give up on that & do what so many others have done, which is convert the system to a single air hose going directly from the schraeder valve under the seat into the top of the air bag so the operator can then manually top up &/or adjust the air bag pressure on the few occasions it's really required! :thumbup:
I doubt that there's too many owners who've had the auto system for a fair while, saaay, over 50 odd thousand miles who'd actually consider the 'automatic' bit of their 'as bought' ACS as a valuable selling point...
I could be wrong about that, but if that's the case
right now, I still reckon it'll just be a matter of time/miles!
