F3 Tail Turn/Brake Light Stock Equivalent?
Sarge707
2015 Model- Searched ALL over and can't find the Stock equivalent for the Rear Turn/Brake dual filament light?
NO Led! Stock bulb replacement from a Auto Parts store. Seems to indicate 5/20 in the Owners Manual?:dontknow:
An 1157 is what you need. Very common bulb. Even if you can't find one with the exact same wattage don't sweat it. I wanted more light output and switched to a high power version (14w/50w) over a year ago now without any problems....
1157 worked with my F3 BUT after 2 or 3 blinks it starts going very fast so its not right- Stock bulb works fine? My bulbs are still Fine but would like to change being pro-active. I'm sure I will use the 1157 somewhere or as a emergency spare.
The BRP help line doesn't even know?:banghead:
I had hyper-flash with LED's and even after removing the LED bulbs and putting the OE ones back in! All you have to do is perform the "re-learning" trick to get them to flash normal for ya.... Lamont has a vid on his site about it, much better to view that than me trying to type it all out! :thumbup:
EDIT: here is the vid in case you have trouble finding it:
http://www.lamonstergarage.com/resetting-hyper-flash/
