Bubby-D
I went and test drove the 2020 RTL that I had mentioned and found a monkey wrench in the process. The bike does not auto downshift. I was cruising at 55 mph in 6th and when I started to brake, I noticed the bike was still in 6th but I was at 40 mph. I hit the brake again, got to 30, and the bike finally started to downshift. I turned around and started back to the shop. I go up to 60 mph, in 6th, hit the brake, and dropped it down to 45, and it was still in 6th. I had to resort to manually downshifting. I've been reading where this is a common problem with the RTL and that some of the solutions are to check the oil level and/or old oil, check battery connections, to a faulty left-hand control module, bad reverse actuator, or bad ECM. Not sure if I want to continue with this buy.
