JDTOLLAND
Hello
I Installed the top case with back rest and speakers on my 2017 F3 T but I have a couple of issues I could use some help with. First the rear cargo light open light on the dash is coming on at times. I saw a fix for that somewhere but now that I need it I cant find it. The second issue is the accessory pug underneath the seat. When it hooked it into the usb port on the case the light did not work. I pulled off the accessory plug from usb hookup on the case and plugged the brp cigarette adapter to it so I could see if it had power and I fried the car charger for my phone that I used to check to see if it power . When I pulled off the cigarette adapter plug it showed a + side and a minus - side. How can I tell which of the two leads in the accessory socket are + or - ???? Any help would be really appreciated.
Thanks
JD
Thanks
JD
