F3's Plastic panel cracked - anyone else/any ideas how? Anyone who has removed this panel have any advice?
Mrmikey
Well-known member
Anyone ever have this happen before and any ideas how it happened? It's not a scratch, the plastics cracked all the way thru, it looks as if it'll be a real pia to replace the piece as it's under a bunch of other pieces. Anyone removed this have any advice?
I wouldn’t worry about it. Too much time, trouble, and expense to replace it.
I'm thinking along the same lines but concerned that it may travel to the opposite side of the the filler cap. May see if I can find some sort of black reinforced repair tape to put over the crack.
Maybe a mixup a little bit of epoxy and spread it into the crack with the edge of a piece of paper and then wipe off the excess?
Never had much luck with epoxy on a thin piece, that's why I was thinking some kind of reinforcement tape on the top. I was considering taking it off and reinforcing the back with epoxy and a screen of some type. Then I figured if I went to that kind of work taking it off, I may as well go with a new piece.
Dilute some CPA glue and let it drain into the crack from a syringe and when it’s soaked in there hit it with some accelerator or a hair drier.
Once dry trim it flat with a razor blade and/or sand it flush. You are going to hide it anyway so you are going to need a flush joint.
Now purchase one of those faux carbon fiber coverings and cover up the panel. Or buy a sheet of the stuff and cut out a suitable shape with it doubled over to keep it symmetric.
Either a vinyl stick on or the other wrap type will work fine. A vinyl type will strengthen the CPA glue bond you made to stop the crack spreading.
Then the thing will look fancy, make your Spyder go faster, and make the problem go away unless you are OCD.
You might consider 3M Clear Paint Protection vinyl. Over the years, I've used it wear points on the paint of my 2818 F3 Limited and it works VERY well. Buy the smallest size, and you'll still have lots left over for other projects on or off your Spyder.
In my opinion, there is going to be very little you can do from the visual side that will hide the crack itself. Any repair attempts should be made from the non-visual side, and while they will re-enforce the crack so it doesn't open up any further, it may not stop it from getting longer. Removing that panel is possible, but most of the front of the Spyder needs to be removed to take it off. From there, hot stapling across the crack or solvent welding using Acetone is possible, but like I said, you'll never hide the crack. Also, while you are there, replace your fuel filter, 'coz it too is under all those panels. If you do come from the visual side, V the crack out to get good solvent/glue penetration, use a filler, & sand the area flush; then you'll need to cover the area in a vinyl/fake-carbon wrap like @mecsw500 said.
Good Luck!
Yep carbon fibre tape is your friend. You don't need to fill in the crack, just tape it over, and job done. This is just cosmetic and will look cool afterwards.
If you want to try to fill it, there is Bob Smith Industries IC-2000 Superglue with rubber. Strong stuff.
Or TufSkinz gas tank stickers
That panel is not that hard to remove. I repaired a similar crack for a friend that was below the gas cap. On her F3, it was caused by an aftermarket cover (bra) that was thick enough to cause a stress crack when the side panel screws were drawn down. From the underside, I used a plastic welding machine to weld the crack together. There was only the slightest hint on the top side of the repair.
