Fairly new here hope this is not a rerun.
Try Trickled.com
Reggie has them available. Large diameter foam rolls that fit over you standard grip. Reggie installs them by removing end of grip, putting hand sanitizer (alcohol kind) in them to lubricate them, slids on then puts grip end back on. Very simple, very effective and he's a SpyderLovers sponsor.
Sorry, but who is Reggie.
Like I said I'm pretty new on here and haven't gotten up to speed. Which sponsor is he?
You can go to most cycle shops and buy "Grip Puppies" off the shelf. They are made of a pretty rugged foam and are made in different lengths. Measure your rubber grips between the raised ends and purchase the appropriate length ones or get long ones and cut to fit. I hear if you remove the end cap on the throttle grip you could have problems with the throttle return spring coming loose. I installed mine the same as above without removing anything. You'll have to work at it but they will eventually go on and fit snug.You will also be able to feel the heated grips through the foam. Can't remember the cost but they were below $15 for the pair. Hope this helps.
I found the grip puppies too larger for me so I went to sporting goods store and bought two sets of tennis handle wrap and put that on. Not so big, and being rubber, gives good grip.
Grips for RT
I just ordered a set of Original Grip Buddies. They wrap around the original RT grips. The heated grips will still work. Should receive them Monday or Tuesday and will let you know! I'm tired of hand ache.
