Fault Code Help P0113 and P0107
CatsJ35
Getting the spyder back together since hitting a deer. While it was apart did some upgrades and now I have 2 fault codes when running P0107 and P0113. Upgrades that may have affected this are TB Juice Pro, K&Nair filter. Also did bajarons wires and plugs, along with led front fender bulbs. Also waiting on a fog light to come in and a running taillight is out but I doubt any of these are the problem, just have heard that if you loose both taillights it could go into limp mode.
P0107:
Damaged sensor, damaged circuit wires,
damaged connector or damaged ECM pins,
ECM voltage supply Low.
P0113:
Disconnected sensor or sensor's resistance too high.
Ah I bet sensor down the right side of trunk might have that unhooked as I'm waiting on that side fog light to re-assemble will check in a second
Fault Codes
P0107 Manifold Air Pressure Sensor too low. P0113 Intake Air Temp too high.
Both could be a problem with wiring.
