Favorite farkle?
jstjohnz
What is your favorite accessory you’ve added? Just judging from signatures, the Baha Ron swaybar seems to be the most frequently listed.
Most bang for for the buck?
On your wish list?
for me the gel seat pad from motorcycledave and then the right side heat block off plate from Spyderpops.
I also think the #1 farkle is the tri-axis handlebars. Not only that, I think the #1 person is......wait for it.......Fred Farkle and all the little Farkle’s. :clap::clap::clap::yes: :yes: :yes:
Best Farkles
In my 2016 F3-T:
  1. Ultimate Floorboards from Pierre.
  2. BajaRon Sway Bar.
  3. Lamonster Fog Light Kit
  4. Bump Skid
:dontknow: I guess that it's a really close tie between:
BajaRon Anti-SwaBar
Doc Humphreys' belt tensioner
It also has Doc's saddlebag hinge supports
Baker-Built Highway bars
A Pete Ameno custom "1330 Triple" vinyl graphic
Spyder Sisters parking lot seat cover
Lamonster Garage Chevron highway pegs
SpyderPops lighted Bumpskid
A pair of LidLox helmet locks
JT's Deash accessory bracket
BRP adjustable driver's backrest
BRP Passenger Armrests
BRP travel cover
BRP full cover
BRP rolling front luggage
BRP hard and soft saddlebag luggage
It has an LED light in the top trunk, so that you can find what you're digging around for.
and the stuff from TricLEDs:
Front fender lights
rear marker lights
LED headlight and foglight bulbs
3rd and 4th brakelights
running, brakelights and turnsignal lights mounted in the saddlebag hinge opening
Wide angle center-mounted mirror​
I am thinking about going that route but it looks like a lot of work. How does your seat look now, the same before you started or did it turn out to be a little wrinkly.
Always in my Signature block
My Favorites are listed in my signature block, though as others have said,
I have too many other farkles to display there..
But if I had to do it all over again, I started with the Tric-Led Ultimate Safety Bundle plus and I'd do that again. Another local here calls my bike Vegas due to all the extra lighting. He hasn't been to a Spyder rally yet and seen lit Bumpskids, and all the other lights available that I don't have.... ;)
And I just ordered BajaRon's Spring adjusters!
Actually I like my little Farkle shelf which is better known as the RT Dash mount bracket.
What I started out with (left) and the way it is now with Waylens Secure360 in the middle.
I got a gel pad from Dave, after it got here and I was checking it all out I found that my staple gun would not shoot into the seat base. So I just took it into a shop and had it installed, was cheaper than buying a new stapler to do the job.
Wish I had three more jobs I would have one of everything going down the road:yes::yes::clap::popcorn::2thumbs:
Let's see...
Well....
Safety....outrigger brake lights and lighted licence plate reflector
Comfort.... comfort seat
Performance... Yoshimura R77, JT air filter
Bells and whistles... guess the pin stripping.... ;)
