That really looks good with the new end cap. What temp paint did you end up with?
...I wonder what that would look like on a silver Spyder?![]()
Looks cool, post a sound byte! Just from being around stainless steel, I'd go back in and install a large diameter washer on the inner and outer wall.
Yes, at the drilled hole. Keep an eye on the, you would need to contour it to fit of course, but stainless loves to crack. Your set-up looks very clean, but since you didn't use a clamp, a 1.25 to 1.5 inch washer should displace the tension over a large enough area. I think I may try your method, keep us updated.
I did say sound byte didn't I?
I installed the same exhaust this weekend and I really like it. Had a micron on before and it was a little to loud. The bike seems to run smoother through all RPM's but then my seat of the pants dyno may not be to accurate. Thanks for doing this mod.
Could this be the re-emergence of Supertrapp and Kerker? Will the king of the '80s rise to rule again? Will overpriced exhaust manufacturers drop off the face of the earth like so many designers jeans companies...probably not.
