Fitting a Baja Ron Ultra Sway Bar - can I thread it thru the gap without removing the wheels?
mecsw500
Well-known member
OK, once I have my Spyder high enough to have removed the old sway bar, here is my question.
I have a 2026 Sea to Sky. It has those fancy new wheels.
What the the chances of being able to thread the new thread bar into place through the wheel without having to rotate either front wheel to align a gap with the sway bar channels.
Once up that high in the air, rotating the wheels is not practical.
Is there always enough space to wiggle the new bar into position in the channel no matter the position of the wheel? Or do I have to get the bike down again, align the wheel, insert the sway bar, and then jack it up a bit to complete the work?
I would appreciate anyone’s experience on this.
I did not need to rotate the wheels. The only interference for the bar is the center frame rail, that is why it has to come on at an angle... it did NOT thread through the wheel at all. Very easy to do with the Ultimate Bar, and the wheels provide no interference.
