Fix Odometer issue - zero-ed with flat battery!
B92MOM
Please, please help!! My daughter has a 2009 Spyder she purchased right before covid hit. She got it titled in her name but never got the chance to get it inspected and tagged. It sat and the battery went dead. She replaced the battery but for some reason the odometer reset itself to zero. The bike had 10,000 miles on it. We have taken it to a dealer that works on Can-Ams in WV and they do not know how to fix it. They say the contacted Can-Am for a fix and all Can-Am told then is that doesnt happen. Well it Did! Anyone else have this problem? If so how did you fix it or what can you do to get it inspected.
You might want to contact BRPcare here on the Forum via a PM to that username or via an email to brp.care@brp.com to see if they can help; but I believe that if the odometer memory in the dash has truly gone, then it just isn't recoverable, sorry! :dontknow:
Good Luck! :cheers:
Thats pretty much "impossible", as the mileage should be stored in a psom/eepro type of chip/system. They do NOT require power to store that info, just powered to have that info wrote to the chip.
Id guess an electrical/shock etc issue that caused the chip to malfunction.
Does it record mileage if you drive it now?
If it doesnt record mileage now, the chip is toast.
You can contact a cluster repair facility to have the cluster repaired & have the correct mileage set in the cluster, BRP should have authorized repair facilities for these cases.
or
BRP may have you simply order a new cluster, they will inform the facility of the required mileage to set it, some states require this be noted on the title.
Anthony G is correct. The total mileage is recorfed in a chip that's part of the display module and cannot be reset unless the chip has failed or the disolay module is replaced.
Are you sure you're not looking at the trip odometer and mistaking that for the total miles ? It's possible the previous owner never reset the trip odometer and both were tracking the same mileage.
:agree: ..... I was going to suggest this as a possibility , but you beat me to it :roflblack: .... I'm not sure I could just get on a GS or RS and know how to work it ..... this may be the case here ..... also I have Little faith in dealers or their Techs ..... jmho .... good luck .... Mike :thumbup:
In the past when clusters needed to be replaced, the mileage from the "bad" cluster was recorded on a tag that was affixed to the frame and warranty booklet. There is no way to add the previous mileage to a new cluster. FWIW
Al in Kazoo
Seems to me like there was a discussion some time back about early odometers resetting to zero at some mileage like 10k or 100k because there weren't enough digits being stored. Could this be the case here?
Or you start with a new bike and what a deal you have there!! I know that's not the right way to think about that, but what the hecks 10,000 miles, hardly broke in!!
You are right. I can't remember if it was 100K or lower.
Al in Kazoo
This would be inaccurate, cluster programming isnt anything new & must be done at an authorized facility.
https://odo-pro.com/digital-mileage-correction.html
Legal:
Programming the odometer on a part to match the true mileage of the vehicle is legal, as long you are not misrepresenting the true mileage of the vehicle. Here are a couple helpful links to information that will help you understand U.S. odometer laws regarding service and sale of vehicles:
U.S. Code 49 U.S. Code § 32704. Service, repair, and replacement
https://www.law.cornell.edu/uscode/text/49/32704
U.S. Code 49 U.S. Code § 32705. Disclosure requirements on transfer of motor vehicles
https://www.law.cornell.edu/uscode/text/49/32705
Please read carefully and understand U.S. Code 49 U.S. Code § 32705. "Disclosure requirements on transfer of motor vehicles" to know your responsibilities when transferring a vehicle.
Legal:
Yes, its all legal but the trouble is the clusters in the Spyders are NOT programmable. Not by the dealer, not by BRP. If you replace a cluster, it starts from zero.
True. There are programmable chips. And fixed chips. Ours is the latter. They are not capable of any programming after being manufactured. I have always wondered if it is because there isn't nearly the interest in cheating with a motorcycle as there is with autos and trucks.
I found the discussion. The problem was the early odometers reset at 100k km, 62k+ miles. BRP issued a fix but it had to be applied before the odo reset.
Thanks for the update. Last night, in the middle of the night what you just posted came to me. I was going to update that this morning. :bowdown:
The clusters ARE writable aka "programmable". Your mileage gets written to the chip in the cluster from the data the sensor(s) send to the pcm/ecm etc, does it not?
If BRP dont offer it, thats one thing. The manufacturers dont offer this service, nor do dealerships. The dealer will send it out for you to an authorized agent aka company or send it out yourself to an authorized company like i linked to above.
That is the same thing with the auto industry, they ALL come set to zero when you purchase one from the dealer.
No, yours isnt the later, its not a "fixed" chip.
They're capable of programming after being manufactured. If they werent capable of programming after being manufactured, then the pcm/ecm couldn't write the data to the cluster chip that it received from the sensor(s) its uses to calculate that data.
As BRP may not want anyone in their ecm/pcm (you have to access the cluster thru the pcm/ecm) to do such repairs, it doesnt mean its impossible. Just like auto manufactures, they gave certain companies access to change the data in the chip with a program, like buds for an example.
You just need the right engineers laptop to fix the mileage, because that laptop will have a full access admin level user for a program like "BUDS".
I believe it is possible to change the mileage with BUDS if you have a megatech license.
Interesting point.
In the description for the Megatech/Mechatronic Expert license. It says "Cleaning ECM, MPEM, CLUSTER "as new" (resetting the hours to zero and miles/kilometers)" . So can someone confirm that this license can set the mileage to any value or just reset to new (zero). As implied in the description.
Been told many times that it cannot be changed. I have also looked for it but admit there are MANY pages in BUDS. If you know for a fact it can be done and where the setting is in BUDS, please post up.
Your theory is all well and good but real world experience has shown its not the case. The ECU does not write the mileage to the cluster. The CLUSTER calculates the mileage from the speed sensor pulses and gives it TO the ECU. Its a simple counter and is not programable. It starts from zero and there are no methods for changing it. Not one instance of this having been accomplished on a Spyder. As far as I know its not even in the Megatech version of BUDS. That value is read only and cannot be programmed.
I would love to be proven wrong as I have always felt it was a major design flaw.
