Axcessitall
So I have been a Spyder owner since 2008 (Read a lot but post very little) and I noticed an issue developed after a few years with my Spyder with the fuel gauge reading LOW all the time. After 60 miles of driving my gas light would come on and I would get about 2 gallons in the tank to fill it back up but still the gauge would only read 1/2 tank at best.
So....
I pulled the sending unit out of the tank (This sucks, I have no words for this but I am sure I did when I removed and reinstalled it) and I took sandpaper to the sending unit fuel level contacts and the little arm that rydes up and down the contacts. Bingo fuel gauge read normal again! I was happy for a year (12k miles) but guess what? It's back to reading 1/2 tank after fill up same as before.
Now being one who does not want to deal with that nightmare of a sending unit / tank removal I decided to try a trick from back in my racing days - BG44K or liquid gold as most dealers, auto shops and high end tuners call it. I added about 3 to 4 ounces into a full tank and drove 180 miles and filled up the tank again. Guess what? This time the gauge read full! The BG44K removed the sulfur (or whatever it is) from the sending unit and all was normal.
One other side note, I was getting about 32 MPG during the first few years (After break in) of having the Spyder but after the BG44K I am now getting 38+ MPG with a noticeable boost in power. For anyone who has ever used BG44K you know this stuff works and for those who have never used it go down to NAPA or your local higher end parts / auto dealers and swing by the service dept and get a can. They are 11 ounce cans and you can dump the rest into your car or ATV or anything else you have with an engine (2 or 4 stroke). They run about $20 a can and this will NOT be found by all the cheap fuel cleaner products but rather behind the counter or in an area all to itself. Keep in mind BG44K is used in just about every "dealer" tune up and you WILL notice it in power and millage.
You only need to add about 3 to 4 ounces to a full tank of gas maybe once or twice a year depending on your millage (I do12k miles a year on my Spyder and only used it once) so it is not like you need to put it in every tank or anything like that.
So if you are having this fuel gauge problem or getting millage that you feel is low go ahead and give some BG44K a shot, it does not hurt and who knows it may just fix your gauge and pay for itself in the gas savings.
Please post your result and let us all know if this worked for you and what your findings are.
Back to reading...
John
So....
Back to reading...
John
