Fobo ACS
Moterofrustrado
I installed a detector in my RT 2014 in the ACS and the problem is that Fobo only measures up to 600 kpa, more or less 90 psi, as the pressure according to the manual without weight in the RT is 85 psi (250 lb cargo + passenger + 250 lb driver) when you go up to RT you always pass pressure continuously warning.The app can not raise the reference pressure to about 120 psi is what it will work. Is this or do I have something wrong?
Nothing you can do about it as their pressure ceiling is 87psi. You would have to install a standalone TPMS device from another maker assuming you can find one with higher operational range....
I believe.....
You are exceeding the recommended weight limit of the spyder. It is only designed to carry 494 pounds total. 250 pounds of cargo + a passenger + a 250 pound driver is way beyond the safety limits of the 2014 RTS. You are seriously looking trouble in the face if that is what you are putting on that spyder. nojoke
250 pounds of cargo? Are you carrying a fully loaded tool kit and lead bars in each storage area, Motero?
......or do you mean cargo+passenger = 250lbs?
Pete
I hope your right......
Pete
and Motero just made a "type-o."
[QUOTE = Motorcycledave; 1380936] Llámame al 209-887-3283
View attachment 164081[/ QUOTE]
[QUOTE = Peteoz; 1381025] ¿250 libras de carga? ¿Llevas un kit de herramientas completamente cargado y barras de plomo en cada área de almacenamiento, Motero?
...... ¿o quieres decir carga + pasajero = 250 libras?
Pete [/ QUOTE]
I weigh 110 kg = 242 lb, my women 63 kg = 139 lb and the luggage 25 kg = 55 lb. which makes a total of 198 kg = 436 lb. This according to manual is 550 Kpa / 80 Lb in the ACS without weight in the vehicle once everything is loaded is more than the limit of the sensor and the App
