Fox podium shocks adjustment
garageguy
Any thoughts on how to adjust preload on a '15 ST-LTD, tools required etc.? Manual says, see your dealer (no help)
Thanks
Sent from my SM-T807V using Tapatalk
I asked my dealer about that and they sold me a pre-load spanner wrench SW-783.
Make a mark with a sharpee or something so you can count how many turns you make to do both sides the same turns.
attachment.php
I just measure the exposed threads with a 6" precision scale. We wound up tightening the springs all the way. Once the springs broke in they seemed pretty weak.
By hand....
Once I loosened the locking ring I found you can turn the spring and retaining ring by hand. Then spin the locking ring up to the retaining ring and tighten it...:thumbup:
I used wide channel locks. They have better grip compared to the spanner wrench.
When you are adjusting the preload, it helps to have that wheel off the ground so the only force on the spring is the preload of the spring. If you do it with the weight of the bike going through the spring it is much harder to do.
Jerry
Any tips on adjusting this? What are the extreme setting (full preload/no preload?) And what's a good starting point while making the adjustment?
Somewhere here or on the FB I posted the ride height chart vs rider weights.
If you are asking that would be a good first setting to baseline from.
Regardless, once the ride height is where you prefer, have the front wheels realigned.
