Front tires - Has anyone tried 165/60s?
A very good tire from what I read hereon, Verdestein Quatrac = 165/60R15, $100.67/tire from Tire Rack
Thank you, didnt know if the 60s would be ok in the fenders, pretty tight with the 55s
If the tire fits under the front fender ( and the 165/60 does ) It should never rub .... the tire and fender remain equally spaced from each other because the fender is attached to the HUB .... same as the wheel / tire ..... Currently the Quatrac is the highest rated tire that will fit our bikes ..... I am trying out a new tire I found ... the RIKEN HR, this is for the REAR only it's a 215/60-15 which is what just about everybody here is using ..... :thumbup: PS these are AUTO tires and your dealer may not want to MOUNT them. but auto tires places can ..... PPS if you use an Auto tire the PSI needs to be lower than stock ie. 15 to 17 front and 18-19 psi rear ...... Mike :thumbup:
Additional size option is 175/55R15. I had those (Federal Formoza) on my 2014 RTL with no fitment issues. And.... They looked great..... Jim
Correct me if I'm wrong but I thought most were using the 205/60-15 for the rear. If not, what is the difference between the two?
Very little! It basically comes down to what's available in your neck of the woods - either size is usually more readily available than a 225/50R15 :thumbup:
The difference is 10mm or about 3/8th in. .... and the Vredestein's largest size is 205/60 or 205/65 -15 ...... Lots of folks here have switched to Vredestein's ...... Mike :thumbup:
Trying to find new 165/55 R15s for the front. Not having much luck. Has anyone tried 165/60s?
HI rperry,
I am running the 165/60 R15 tire size, I found Continental Contiprocontact's on Tire Rack.
I replaced the OEM's on 6/24/2016 with the above tire. The space between the fenders and the tire is about 1/2 inch( of the thickness of my pointer finger). These tires do not rub on the fenders.
I have a 2014 RTS-SE6.
The ratings on the above tires are: WET..................... 7.0 Good Wet Trac. 7.1
DRY......................7.7 Good Cornering :7.5 Dry Trac: 8.0 Steering Response: 7.7
I haven't had any problems with the above tire.
Deanna
I fitted 175/60-15 Michelin's on my F3s, and they fit just fine, I learned from Mike that not all tires are created equal, but for me they fit like a glove, that's too tight...So me thinks you won't get in trouble fitting the size you stated
The OEM tire sizes on the Spyder are oddball sizes that hardly anyone else other than Kenda makes. If those sizes are used on any cars I'm not aware of it. That's why you can't find them.
Just to throw something else into the mix, I just fitted 175/65R14’ on my RSS with no problems what so ever. I know it’s not the same but I just wanted to point it out.
I have 165/60s on my 2015 RT-S Federal Formosa AZ01. Got mine at Walmart.com $55.00ish picked up and took to my tire dealer got them mounted and balanced.
rperry,
I am running the 165/60 R15 Continental Contiprocontact I got in 2016, they have 24, 115 on them. I change the OEM to Continental Contiprocontact's.
I have about a finger's thickness between the fender the tire( look at My Albums ) for pictures.
Deanna
