SportsterDoc
PMK: "Higher altitude results in less dense air, so less air compressed into the cylinders, corresponding to a lower compression ratio, which requires less octane."
Less air compressed corresponds to or has the same effect as a lower compression ratio.. I did not state that it changed the compression ratio.
Please advise if you need further clarification.
