tbjohnson10
I have an 08 RS SM5, had all these faults (ABS, EBD, VSS, Check Engine, Brake Failure) a few years ago and just put the bike up after a dealer wanted $3k to switch out VSS before even troubleshooting.  Pulled bike back out, put in a new battery, fired right up, and have been trying to address the codes again.  Have bled the brakes a few times, and this morning bled the VSS - brakes are still spongy and can be pushed all the way down.  I took each caliper off and as the brake pedal is pushed, the caliper does tighten.  When bleeding the VSS, it was only pulling fluid from the front reservoir (thought I read that it would pull from both). I can get the faults to reset by holding the brake down for 30sec after turning the key, but faults come back after cranking bike and revving the motor.  When I pull the codes, I get 1282 1210 and 2545. I was going to try Speed Bleeders on all 4 points and bleed again, putting new pads on the back to see if that helps before taking it to another dealer.  Any other suggestions are greatly appreciated.  Thanks
		 then it's gotta be worth a shot, doesn't it?!
		 pps:
pps:
