Got an Over heating warning at idle, went away riding - any ideas what could be wrong?
Cuzinjoe
Hello everyone, I have a 2020 Can-Am Spyder F3 limited. I changed the oil last week and topped off the coolant. Yesterday I went for a two hour ride and 75° weather. We stopped to eat for about an hour and a half. I started the bike and let it out while I was putting on my gear at that time. A warning light came down and stated engine temp too high. The temperature gauge is all the way up into the red. Mine was only running for about five minutes and it was cool outside. I was only 10 minutes from my house so I got on the bike. I started riding within 30 seconds. The temperature gauge just dropped down to normal and the warning light went away. I just put a brand new battery in last week. Anybody have any idea what could be wrong? I’m going on a trip in a few weeks to Laconia.
Thank you
Reply
Did you check the radiator tank cover? Assuming that there are no signs of leaks. Could be that there was some air in the system. Keep an eye on the coolant levels, and check what codes may have popped up.
Agree with stated above, as well as my 998 V-twin - the ambient temp sensor has gotten too hot parked in sun, no airflow, (104° F, when it was actually only 70°) The sensor is located in the air box to adjust the fuel air mix.
Depending on how "low" the coolant was I could also agree on air bubble. If it doesn't do it again on kind of a regular basis you're probably good to go. If it comes back regular like, look to a sensor probably.
If you know where the water pump is, you may want to check the weep hole for signs of leakage also!
