GREAT SPYDER CODES APP
leenysride
Found an App called Spyder Codes that not only explains the codes, it also shows you dealers or garages in the surrounding area you're in during ride, help menu, videos and more. You set it up for your year/model. My problem is that my code, P20EB, says main relay. I replaced them both. No reset on check engine error. Then I removed negative battery cable for a hour. No reset. Any ideas ???​
