Has anyone tried to put a Harley trunk on a F3 Limited? I'm sure that fabrication of a mounting bracket would be the biggest challenge. The factory trunk is just too expensive for my budget.
No--but I bet it would be exciting to pass a group of Hells Angels:yes:
I have this one on my Kawasaki Nomad, https://www.amazon.com/TMS-TBOX-JK1001-K-Motorcycle-Luggage-Backrest/dp/B00513G82U. the shell is a little thin but it has held up for almost ten years.
I thought mine came with the trunk that you can put 2 helmets in and it was a Limited. Your's didn't?
As I understand it, the top trunk is a $2,000 add-on with installation.
, If you do a search on E-bay you will find about 5,000 options .... all sizes, shapes, colors, with or without racks, passenger padding etc .... you can narrow it down a lot buy using the chart on the left ( always click FREE shipping ) ..... It's a bit time consuming but worth it ...imho ..... good for a rainy day :roflblack::roflblack::roflblack: .... Mike :thumbup:Here is an idea I am leaning towards - saw it on "the spyder experience" FB site.
The box can be purchased from eBay for less than $100 and the luggage rack can be fabricated as shown in the pic from the OP or purchased.
View attachment 153120View attachment 153121View attachment 153122View attachment 153123
The 2017 limited comes with the box, but the 2016 limited didn't. It can be added. As for me, I would rather have the 2016 and then add the box. That way you will end up with the larger sprocket for better acceleration.I thought mine came with the trunk that you can put 2 helmets in and it was a Limited. Your's didn't?
I've been looking at different options to add a top case on my F3T.
The BRP one is just way too expensive and way to cheap. Adding to that that my wife was not as confortable as she is with my actual backrest, I needed to find something else.
I wanted to keep the BRP Backrest so I haven't found any rack that fits my needs.
I ended up building one.
Here's the results!
View attachment 153154View attachment 153155
The beauty of it is that you can add a box or not and everything is still accessible.
That should work. What brand make model is your top case. It looks great in your pics. Had I been able to actually look at and check out the new F3 Can Am BRP top case I would not have purchased it. As stated previously I am not impressed and very disappointed.
