RockyMountainRider50
Thus far my attempt to install C/Dynamic TIPZ Unit, front Mudflap lights, and Brightside amber has been a success. Also changed the OEM bulb in the fender tip! The Magicflex Channels wiring has caused the delay. With only three colors of wires (Red, Black & Yellow) it has slowed my progress. Per instructions when TIPZ Unit are installed connect Black to Black wire, and Red to Orange wire (before the TIPZ Unit) I have attached tried both before and after the TIPZ Unit with no luck for power. I've attached the Yellow wire to the turn signal harness with=in the mirrors. This has got to be wrong! Needing to find out where the instrument cluster is located. Instructions for magicflex. Channelz state that on page 107 of owners manual you must remove the instrument cluster and attached the yellow wire to the appropriate directional/turn signal. Still looking for the instrument cluster in owners and shop repair manual. I've read in the shop manual one place with a cluster (front fuse box). Can any one confirm this as the instrument cluster? Any suggestions?
