Has anyone had issues with electric parking brake not engaging after long rides then working an hour or two later.
my wifes spyder
Has anyone had issues with electric parking brake not engaging after long rides then working an hour or two later on 2016 RT Limited.
I have a 2015 RT-S SE6 and after 8 hrs of riding in the heat, two hydration breaks and an hour lunch break in the 91°F temps, my parking brake would not release after it did when I applied it to go open my garage door. I had a brake failure alarm. Eventually, an hour so later, it released and I put my Spyder in the garage. The next morning, I sprayed the cable end with RV Slide lube, aka silicone, and applied the park brake. It worked fine then. I believe my issue was the heat and also that I had been riding on gravel roads in Ohio.
There are some good YouTube videos on park brake issues.
The cable could use lube like said above, your switch may need a little also, or if it keeps doing it you may want to carry a meter and when it acts up check to see if you have voltage coming and going to the places it should be going. I hate electrical Gremlins!
