Has anyone looked at the top of the Fuel Pump from the inside? 2024 RT Limited
jdgretz
Well-known member
Has anyone looked at the top of the fuel pump from the inside? There is a third nipple that is unused and blocked. Does that go through any sort of valve or filter in that housing or does it dump directly into the tank?
I'm thinking that could be the line for an aux fuel tank inlet.
Thanks,
jdg
I do not understand the desire to carry extra fuel vs the danger that presents?
I did a 6 day 1850 mile ride back in May of 2024 and fuel was never an issue.
Now riding to Alaska:
  • Average Distance: Services are typically available every 20-50 miles, but remote areas have gaps of up to 100+ miles.
  • Specific Stretches: A notable stretch of up to 160 miles exists between Teslin and Watson Lake.
  • After-hours: If traveling at night or off-season, distances between open stations can significantly increase.
  • Recommendation: Keep your tank at least half full and carry extra fuel for safety.
Well you keep doing you and those of us who like IBA style riding will do what we enjoy.
I've ridden out of Death Valley heading toward Ely, Nevada, got well past the sign that said next gas 167 miles, ran into snow about 30 miles outside of Ely and had to turn around. Yeah, I was real happy I had 300 mile range on my Goldwing.
Here's a typical trip for me.
A good portion of the Northern California portion of CA1 was at night with unknown fuel availability. Having that cushion is nice.
jdg
If it’s anything like the Ryker, the extra barb goes into the tank. I’ve drilled mine out to use as an auxiliary tank dump.
View attachment 253583 - View attachment 253584
That looks promising. Are you doing a gravity feed or using an electric pump?
The one on the RT looks like this, and the red circle is the nipple that is plugged and apparently goes to nothing.
jdg
If you ride some of the larger National or State Parks, or the Blue Ridge Parkway and other places like that, you will run into plenty of roads where fuel can become an issue. Some of the larger National Parks have roads with more than 100 miles between gas stations or even small communities. Riding at night does make it more likely that most of the places where you can get gas will be closed. The Spyder has more fuel capacity than the Sportsters I rode. I would still carry extra fuel. I never understood how a little extra fuel on board could be any more dangerous than a thin metal tank with 4 gallons or more between your legs. You are not likely to still be sitting on the motorcycle or even near it after an accident. Bad as that may sound, it is true.
It is only in the movies where the vehicle goes off of a 200 foot cliff and explodes half way down, before it ever hits anything.
Jd, I’m running a low pressure external fuel pump from an aluminum 3.25 fuel tank mounted behind me on the max mount. I’ve ordered all the parts, just waiting for them to arrive and a warm day to set it up.
Sounds good. Take lots of photos, I want to see how it works for the Ryker.
jdg
I started trying to figure out how to get the auxiliary tank mounted and plumbed. There isn’t a whole lot of space to work with as the Ryker is small and narrow. Here are a few photos of where I think things will be located. For mark up I’m using odds and ends from the scrap bin in my basement. Once I get it all figured out I’ll take it apart and dress it up to look better.
Thanks. The Ryker tank is about 5.2 gals, the auxiliary is 3.75. Mpg is pretty low, maybe 32 to 36 mph, so maybe 280 miles range. Time will tell. I need to do another one for the wife’s Ryker after I get this one sorted. We are doing a trip from NJ to Bishop Ca in May.
Update: we took a trip from NJ to Louisiana then up through Alabama, Tennessee, NC, Virginia, then back to NJ. The setup worked great, the only issue we had was that one day got into the mid to upper 90s and the tank built enough pressure to overcome the pump and check valve. That pushed fuel into the tank, so we noticed we had done 170 miles and still hadn’t hit the low fuel light. A quick stop confirmed the auxiliary tank was down on fuel. From that point we ran with the valve off until needed. I’m going to look into a better venting cap to prevent that. It’s great having the extra fuel and not having to think about it until 200 miles or so. We ended up riding 3957 miles on the trip.
I finally got my hands on a pump. The good news is that yes, I can drill out that nipple and fuel will dump into the tank. The bad news is that it will also dump right on to some electrical connections. Probably not the best idea. The existing fuel lines are sealed at the top so that fuel does not come in contact with the wiring. Given that the electrical stuff does not seem to bother the fumes in the tank, I'd probably be OK dumping fuel there, but I think I'd rather have the fuel entering the tank via a hose or an extended nipple inside the pump that goes down past the exposed electrical stuff.
EDIT: Added a photo. The red circle is where the fuel will enter the pump.
jdg
