Has anyone tried Reverse Brake Bleeding on their Spyder? Was it effective?
LoRider
Has anyone tried reverse brake bleeding on a Spyder? If so, was it effective? If not, does anyone see any reason why it might be a bad idea? Seems like a pretty logical and quick method on a 2 wheeler.
As in forcing the fluid backwards into the reservoir, never heard of it?
If that's what you're meaning I can see only disadvantages main one being you then have to suck the fluid/crud out of the reservoir with more chance of spiling it on the paint.
We need to distinguish between flushing (pushing new fluid through the system to force the old cruddy fluid out) and bleeding (getting all the air out of the system). If you do the former correctly you may not have to do the latter.
To do flushing I like to replace the bleed nipples with Speed Bleeders. Or use the OEM nipples but start with some brake fluid in the drain container and keep the end of the drain tube submerged in that so it can't suck air back in.
If you do get air in the system, pushing fresh fluid back up from the bottom can be an effective way to remove it. But do that only after you've flushed out all the old fluid.
The only time reverse bleeding (yes not flushing) helps out is when the master cylinder is both lower than the brake line and the reservoir (fed by a hose). There you really need to force fluid backwards to get the air out.
I’m asking about using this method for both fluid replacement and prevention of introducing air into the line. Fluid in from the nipple into the reservoir, and suctioning out the cruddy fluid from the top.
If you first suck out the old fluid from the reservoir, give it a wipe out, put a bit of new in it, wipe it out again then fill it up with new and then either pump out the brake cylinders, draw it thru the system with a vacuum bleeder (way I did mine) or use speed bleeders, I think it'd be the safest way to do it. I don't see the advantage of going the other way, it'd work for sure but I don't see an advantage.
