Headlight aim adjustment
Gunner 02
How do we adjust the aim on our RS? I have a 2012 RS and my headlights are aimed just a little high, want the adjust the aim down just a little to cover the road better. Anyone made these adjustments?
Not hard..
on the front cowl under the headlight lenses you will see a small hole. Phillips head screwdriver inserted will reach the adjuster screws. Clockwise will raise the beam counter clockwise will lower it. You should find a wall set the spyder 35 feet back and make your adjustments. If alone the best is to put weight on the seat to match yours...or get on and off. Sorry don't remember the hight you need to mark on the wall...:thumbup:
Great information and I found them to make the adjustments. Thanks for the help.
