Heat Issues, Here is a remedy
Ok , so perhaps I'm just annoyed at riding around on a warm day with my umm privates roasting like chestnuts on an open fire , or maybe I'm just odd....but I have found an area that is letting heat come up and the solution should be pretty simple. Where the front of the seat meets the glovebox there is a large amount of heat that escapes up right into you crotch area on the right side . the left side in front of the gas cap is pretty sealed and very little heat seems to come up but there are areas that engine heat comes up between the seat material and the plastic on the inside of your right thigh. I haven't been out to the garage to look closely but this should be an easy easy fix to redirect it away from that gap.
Not sure
I can't tell what you did....
