Heated Gear
MangoMike
Does the RT have the ability to power an electric jacket and gloves. It would be great if someone made a controller that monitored the battery and would automatically reduce the power used, or turn itself off if the bike was not generating enough power. I am afraid of running down the battery while riding with heated gear, stopping somewhere, and not being able to start the bike again.
Anyone use heated gear? Any advice?
Mike
Heated gear
Your bike may already have a plug under the seat thst can be use for a jacket. If it's like mine the fuse is only 7.5, I ran another line with the Gerbing setup, comes with a jacket and most other accessories and it's good for 15 amps. The bike has 650 watts to play with and a jacket is about 80, max. There seems to be enough to power a jacket and pants for two, unless you have lots of extra lights, etc. The Spyder grips are very warm on low, haven't even used high yet.
Tuck
Lots of us use heated gear with no problems. My wife and I have used our heated jackets/vests at the same time (different circuits), along with the heated grips front and rear, and I have used my vest and the heated grips together, too. The only thing I would recommend is that you keep the rpm up. The Spyder only develops about half its rated electrical output at 4,000 rpm. Running around at three grand, or keeping the heated gear on high during stop-and-go traffic, is probably not advisable.
I like the idea of a smart controller, that can dial back the heated gear settings when the battery voltage drops, but it would be hard to achieve. By the time the battery voltage hits substandard levels, the draw has already been too high for too long. If you could separately monitor the magneto output, that would be ideal. No more pesky dialing back the settings at a traffic light. Maybe some smart electronic genius can come up with a solution someday.
Remember that heated gear has to fit snugly, over a minimum of under-layers, to be the most effective. It is best to size the gear in the store, if possible. Gerbing has a lot of sizes, to fit you to a tee, and they often have fit seminars at selected stores and shows...it is that important. Powerlet does the same at shows. One advantage to the correct size and base layer(s) is that the gear needn't be turned up so high, lessening the electrical draw. In fact, I often ride with my vest without turning it on. It is a real effective warmth layer without the heat.
Plug?
Where is this plug?
Tuck
Heated gear
My wife has Gerbing, gloves, pants jacket liner and socks[COLD NATURED] and used all basically everyday for 3 weeks straight on our trip to Alaska in may, I installed a Kuryakin LED volt meter to moniter voltage [we travel alot] when she got her bike, she does turn down in town but have never had an issue, plug in connected directly to battery. I connected the hot to the volt meter to the red wire going to the passenger seat switch 40,000mi. ago so I assume this spot is ok.
I installed a relay controlled fuse panel and my gear is fed from there. The fuse panel only has power when the bike is running (I can even turn the key on no drain). I have a volt meter that plugs into my dash power outlet so I can check power draw. My heated gloves and coat draw very little, the voltage does not drop even during idle (my 55 watt driving lights drop the voltage considerably).
I have First Gear heated clothing with a remote heat controller. This small box with 2 knobs fits under the dash and has its own battery. It sends a signal to a recieve in the heated jacket which controlls the gloves and Jacket. The remote includes the reciever and runs about the same price as the hard wired unit.
Regards,
Randy
My humble advice when using Heated gear in extremely cold temps, Make sure you have exta clothing with you in case of a heated gear failure. ; ie, fuse, lose connection etc.
I know of one case where a rider got off a bike and forgot to unplug his jacket from the bike and ripped out the wires,. That was one cold ride home.:shocked:
Mike
Might be worth checking this site out, http://shop.mobilewarminggear.com/home/index/4638.0.1.1 They were at the appreciation day at C F Powersports earlier this month. This heated gear uses rechargable battery.
