InspectorGadget
Anyone have a good location to securely mount helmets when fully loaded with gear for touring?
Thanks C-YA RL
			Thanks C-YA RL
2010 RT-S SM5Which model of Spyder?
There are plastic hooks under the seat on both sides that can be used to hang the metal buckle. Simply close the seat and the helmets hang down the side.Thought there were helmet locks under the seat? :dontknow:
Hey thanks loads. We were so excited looking at everything else we must have missed them.There are plastic hooks under the seat on both sides that can be used to hang the metal buckle. Simply close the seat and the helmets hang down the side.
Glynnk
Thank you so much for the info and the link. It was most helpful.There is a helmet hook on each side, under the seat, on the RT. They work quite well, although they are too far in to use the helmet D-ring. Just fasten the helmet strap and loop it on the hook, then carefully close lock) the seat. In inclement weather, I suggest covering the helmets, seat, or both. The Owners Guide (accessible from the BRP site Owner Center), shows a picture on page 40. No such hooks on the RS.
2 full face helmets will fit in the frunk. Place the top of both helmets down so the 2nd is inside the 1st. It worked for me, just an idea
We went to Leesburg yestarday, and there was only room in the frunk for full face helmet. I had to put 1 in the helmet bag and tie that to the underseat helmet hook. Not the best or most secure setup.
Soooooo I came up with the following solution.
125 lb. test aircraft cable from Home Depot.
Notice that the helmet actually sets on the rear running board too.
C-YA RL
I cut the cable 15" long.Love this idea. Will have a pair by next weekend. Thanks! :2thumbs:
