Installing a rocker switch USB C charge port - any reason this won't work?
Baird4444
2016 Spyder RT limited - Old Man Edition
I'm installing an inline fused rocker switch style USB C charge port. The center blank had a round hole, so I can cut a new one to fit. I have read of others having problems with the existing hole under the blanking plate being too large... but I'm feeling Lucky...
I am going to get my HOT wire from the fog light plug, the Orange-Red wire probes as hot when key is on. I think I'll grab a ground from a body panel screw about 10" away. I there any reason why I shouldn't do this?
I'm going to ponder the rest of the evening and plan on doing the job tomorrow, unless someone has a good reason not too???
Any and all opinions and options welcome... Thank You - Mike
Not sure what the draw on the fog light plug is, but those inline fused rocker switches with USB's tend to draw up to 6 amps (fused at 10 amps) so you might overload that line or blow the fuse. I would run a fused power line from the battery into a 20 amp headlight relay that turns on when the ignition is on. I hate tapping into any of the Spyder's wiring with high amp devices. To power the relay, you can draw off the lighted switch wire, since the relay power doesn't draw much. Then run the power from the other side of the relay to your USB switch. The nice thing about this is, if you run a 10 awg wire from the battery, you could run multiple devices, within reason of course.
Relay = (Pin 86) +12V Keyed (Pin 85) Ground (Pin 30) +12V from Bat (Pin 87) Goes to USB Switch.
Here is part of a wiring schematic I did for my High/Low beam LED running lights. I added an AUX switch where the blank switch was in the dash. I did put a fuse between the yellow dash light wire and the relay on my Spyder.
Just my 2 cents worth. :)
Mike
Thanks for the rewire setup @Elqueso2, if my plan fails, I'll save it for the Re-do...
I didn't know that the switches have to be accessed from the bottom, short harnesses as well... It took a lot longer
taking the tupperware off, but I'm getting quicker at it. All good, happy with the outcome!
If you ever want to change the switch out, you can buy one that you can configure in any way. I used this one for turning on my running/high beam spot lights. Internal LEDs match the other switches on the dash. Glad you got it working.
Mike
There should be two fused switch power sources for accessories. One is behind the fuel tank on the passengers side (called GPS power), the other (closer) one is in the frunk behind the rubber plug on the drivers side of the battery. There is another recent thread showing that power source.
