obiwanbill
Since my Maintenance contract was up, I decided to do some wrenching myself.
Got a Spyder 2008 GS SE5 oil change kit: the large bottom oil filter, little higher up 'transmission filter", o rings, brass washers for the tank drain and the engine drain. Took 45 min to get off all the "tupperware" (not bad from a wheelchair with one leg), and 2 hours to get the over torqued tank bolt out (like to chew out the last mechanic that must have had the strength of Superman...I bent 2 Allen wrenches before it came loose).
HELP!!
the instruction sheet directions and photos for the li'l trannie filter, Does not clarify. The old filter had a hole opening with a rubber gasket on each end (not the O ring). The new one has a solid metal cover on one end and a hole with a rubber gasket on the other. It wasn't saying if the solid end inserted into the new filter cover or it was to be facing the engine. I put it in with the rubber gasket facing the engine and the solid metal end facing away from engine, snug into the outside filter cover.
Did I do it right, or do I have to tear it apart and reverse it? :yikes:
HELP!!
