Weave2u
I have an '09 GS. A few months ago, I took it in for the 9k service. When I got it back, it seemed I could hear what could be a minor exhaust leak. I didn't make too much of it because the shop just had it. Well, it seemed to get worse and the mc seemed to lose a little power (I generally ride it everyday to work (45miles each way), plus shopping, etc.). It finally got loud enough that I decided to park it until I could track down the leak. Well, I found a pretty good leak on the right side at the exhaust connector. It looks like there is a small amount of heavy gauge steel wool inside the ring of the connector (I'm guessing to allow it to be tightened further). The leak itself (which I would describe as pretty severe) is where the ends of the sleeve meet. I'm no mechanic, but as far as I know, there should be no leaks anywhere along the path from the engine to the muffler. I tried tightening it down as much as possible, but it still leaks. Any suggestions? I appreciate any help, because I'm stuck with the cage until I resolve this. Thanks!! BTW, the leak is aimed right at the engine housing.
