kevorama
MOgang Member & Pyro-Man
I'm trying to beat a storm that's rolling in and I can't reach Reggy on the phone at TricLED. If anyone has installed this, please advise. My issue is that I'm also installing my rear side marker Brightsides at the same time since all the rear tupperware is off. For the upper strip, I'm supposed to trial fit starting from left to right. That's easy. I end up with about 7" left over on the right. I'm afraid to cut the excess because I've never worked with strip lighting before. I have a 15' roll of RGB that has to be cut in between every set of RGB LED's. In other words, if there are 3 LED's per inch and they are RGB I can't make a 5 1/2 inch piece because I'd be cutting in between the RGB phase of that last 1/2 inch. Does an all one color LED strip fall under the same rules? A reply ASAP would be greatly appreciated.
Thanks in advance
Kevin
Thanks in advance
Kevin
