HID Fog Lamp
jsmj
I bought a 2014 RT-S few months ago and I like to change the fog lamp to HID light , do anyone know how to take the frunk off?
FRUNK REMOVAL
There are a couple a good video's showing how..........I just did mine , it's like 8 bolts then lift it off the top clips by the two fuse boxes........do a search for the vids......Mike :thumbup:
I saw four bolt on top and not sure the bottom where the bolts located, where I can find the video that you mentioned?
The frunk has 4-10 mil bolts up front under the head lights and 2 underneath that face toward the rear. There are several electrical connectors that need to come apart then lift up and come back with the entire assembly. I use my motorcyle lift to make it easy by my self after first raising the bike and putting it on jack stands. I did the same thing (installed HIDs) and there is a lot of relays, ballasts and wiring that has to go some where. I mounted this on the back of the frunk so it all comes off in the future by disconneing the HID wiring. Now that LEDs are being sold I recommond them instead, no wiring just plug and play. The Fog lights did not imporve with HIDs, they just look whiter.
TRUNK WEIGHT
:yikes:.........mAYBE ...35 LBS. empty......IMHO......Mike :thumbup:...........When you undo the BOLTS do the ones underneath first....then the TOP FOUR.....The FRUNK will not fall off .....You actually have to lift the front ...tip it back ....and lift it off the clips ( by the four top bolts ).....Mike :thumbup:
