Highway Peg Alternative RS-S
carob998
Hi All;
Installed these as highway pegs for the RS-S. Here's what I used each side:
  • 2 1/2" long x 1/2" dia S.S. bolt
  • 2 split washers
  • 2 - 2" square flat washers w/ two sided tape to better secure to bracket.
  • #7573 Magnum peg Mount by Kuryakyn
  • #7560 Trident Small Pegs by Kuryakyn
Info: I weigh 160 lbs w/ a size 9 boot
Just completed a 600 mile round trip and thought they worked well. A few items to note:
  1. [*=1]Used just a few times to give old knees a break
    [*=1]May not work with larger boot sizes
    [*=1]Wifey can use driver pegs to stretch out for a little while
    [*=1]A little bit "bouncy" when going over uneven pavement, but pretty solid otherwise.
What you all think?? Likes or dislikes.
Rory
Interesting....🤔
Well done and a nice set up.:2thumbs: just have to watch the weight on them. Those foot guards are not that sturdy but knowing that should work well...:thumbup:
Thnx
Thnx. I only used it couple of times on the last trip and it worked well.
You can also rest your heel on driver pegs and toe on added peg, so as not to put too much weight on the bracket if you're worried about bracket
A little bit of forward foot position goes a long way.
Rory
