flybuddy
Pic 1--made a mount out of aluminum (first did it with very thin material and used as a template for the thicker stuff--used .061). Drilled two holes on the circular ends and mounted under the lower handlebar screws.
Pic 2--Here's a link to a usable mount $6.90 (I cut off the strap and drilled it to the aluminum mount), it's fairly difficult to find straight 17mm ball mounts that Garmin uses. Another method is to get a 17 mm bead or cut a ball off a curved Garmin mount--shave the top and drill a hole through it.
http://www.ebay.com/itm/330660309834?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Pic 3--finished poduct--I cut a piece of plastic and velcroed on top for a sun shade
