How about some ideas for cup / bottle holders? F3-T 2021
Is she a driver or passenger? I just installed a Kustom Kaddy (also called Kruzer Kaddy 750) for the driver. I have in on the right side. I would describe it as "Adequate but not ideal". I also added a Kemimoto ATV cup holder onto the passenger grab rail. It came with a little rubber pad that will, hopefully, keep it from damaging the grab rail. Previous to my 2021 Spyder F3 Limited I had a Goldwing. There are many options for a Wing. But not as many to choose from for the Spyder. Maybe someone has other recommendations. I can upload a picture of these if you want.
Amazon and some hardware stores have a chrome clamp that will bolt right on the frame tube just below the fuel tank. I don't remember the size, but I used one of them to add a leg rest to my Spyder. Get the correct size and they will bolt on solid and secure, then you just add any kind of cup holder (or anything else) you want to them. Might find them at auto parts stores to be used for exhaust clamps.
:agree: +1 on the LaMonster frame mount bottle. However, keep track of the straw when you clean it. Mine fell into that black hole in my kitchen, never to be seen again. I've tried several but can't find one to fit.
I picked up holder for my F-3 and my wife's at a bicycle shop. It was only $15 and holds a 20oz. bottle securely. I put on the drivers side handle bar because I feel there is more control when removing the bottle.
I picked up holder for my F-3 and my wife's at a bicycle shop. It was only $15 and holds a 20oz. I put on the drivers side handle bar because I feel there is more control when removing the bottle.
Drivers side, that be the left side I take it? Front and rear, left and right on most bikes .
I was wondering about this one myself, it seems like a metal bottle in that position would pick up a great deal of heat off of the engine during summertime do you have any issues with that?
The bottle he sells with it is insulated and keeps liquids cool. I use an insulated Water bottle made by Corkcicle. Either the 16 or 20oz bottle. I'm thinking of adding a hydration tube to it so I can drink while riding. I also like the pouch to hold my Gerbing heated cables.
I use the same. I use a taller water bottle than the one provided by Lamonster. I added a small piece of clear bra tape where the bottle touched the paint.
