How do you handle making or receiving a call while riding when BT is connecting your GPS, comms, and phone?
UtahPete
Well-known member
I have the Garmin Zumo Xt, Sena 20S comms and an Android (Pixel) phone. Based on research, I understand the best way to connect them is to pair each of the phone and comms to the GPS, but not to each other. This I have done and it mostly works; I can hear the GPS commands thru the Sena speakers, and I can use the Sena speakers and microphone to conduct a phone conversation.
The limitation is in receiving or making a call while riding, because the Sena jog dial and phone button don't work at all and those functions must be done through the GPS interface (the BT connections provided for audio signals, but not operational commands apparently). The GPS interface for receiving a call presents a button on the screen to push, which is dicey when riding, particularly with gloves on, because the button is fairly small and surrounded by other active touch-screen functions. To make a call requires navigating a series of menus, which is impossible while riding.
Has anyone dealt effectively with this issue? Thanks.
Sena paired to phone, then Garmin Tread paired to Sena but not to phone. Works great for calls. Sometimes I'll also pair the Garmin to the phone when I need some of the additional features like weather or connecting to the Tread app. But I very rarely use the Garmin for turn by turn directions.
I used to set my phone to auto answer a call when connected to any BT device. There are obvious issues with this.
Now I just let everything go to voicemail. I'll call them back when I stop for a break. As you mentioned it's dicey trying to make a call while riding and I don't normally try.
Of course, I'm retired and no call I get is important anyway, so your situation may be quite different.
If you don't mind not being able to screen your calls, then the auto answer works ok.
I use an Aoocci CarPlay/Android auto device connected to my phone, and Cardo Edge coms, everything works for taking calls, making calls using voice in my case Siri. Nav turn by turn instructions come over coms as well because I am using Google Maps on CarPlay. I know some folks use both a Aoocci type device and a stand alone GPS both.
