How many have tried Wilbers Shocks?
Had them on my BMW RT. Big improvement over stock and the stockers weren't bad. They have a pretty big presence in the BMW world. No clue how their Spyder offerings rate.
You might want to check in with Peteoz, AbNormy. ;)
IIRC he's kitted out his F3 with Wilburs all round, and I believe they are really working well for him; & I think that's after he tried some of the competitors shocks! :thumbup:
curious how many have tried the wilbers? cost seems better...
I have them on my 17 RTL. A mate and I swapped so that he could test them with his better half and within 20kms I could see the smiles on their faces. he ordered new shocks the next day.
I have been very very impressed with them, and they have solved a lot of handling issues that the OEM shocks cant fix
  • more stability in rough cornering,
  • less twist in the front,
  • anti-dive like behavior from the valving,
  • "adjust-ability" that allows you to tune them to the ride you are having
  • more confidence in the wet
  • more feedback from them to the rider (even my wife recognizes some things now)
  • great ride around town where you notice the smoothness straight away
  • the ability to adjust the rear without being a contortionist
  • complements the air shock nicely by controlling the rebound and compression, removing the pogostick type effect.
if you have an RTL with the auto-leveling, it may upset the auto-leveling when the system is raising the rear, but this is easily dealt with.
In Australia the set that I have costs approx $3500 (with the external rear shock adjuster). I'd spend it again if I bought a newer model and found they dont fit.
My response is exactly the same as Askitee, AbNormy. Unfortunately, I have only had the Wilbers, and not their competitors, so I can’t comment from that aspect. For me at 300lbs, they work an absolute treat and have been trouble free for 3 years. I have to say that I don’t remember them being cheaper than the competitors when I was searching. Just make sure you are comparing shocks with similar levels of features:thumbup:
Pete
these don't need rebuilding as often as the ones Lamont sells do they?
That I'm not sure about, I havent been able to find anyone who has needed to rebuild them. I am of the understanding they have kits like other manufacturers.
On a side note, Wilburs asked for :
  • What riding style did I want them set up for - Sport/ Sport+Touring/Touring
  • How often am I two up or towing
  • What weight am I and my pilion, with our gear on (if you're married you'll find this the hardest to get accurately)
  • What ride height I wanted (current or slightly lower)
Yeah, I don’t know if you don’t hear of Wilbers requiring rebuilding because there are far fewer of them on the site, or if they genuinely last longer, Ab. I have had no issues with mine in 3 years.
......and as soon as I told the vendor - weight....140kgs (300lbs).... he didn’t ask about whether I rode 2up, or the ride height I wanted, Askitee. ;) ...... looks like I just got the upper limit on everything :thumbup:
Pete
Their web site shows $1199.00 for the front pair, and says the rear is required. It shows the rear at $695.00 until you click on it, then it magically becomes $766 or higher!
Pete
More "robust" Pete :)
