How many quarts of oil needed for oil+filter change? 2020 RT Ltd
How many quarts of oil are needed for 2020 Spyder RT Limited for oil and filter change? I put in a little over 5 quarts. I can't tell on dipstick exactly where its registering.
Oil Check
:coffee: Check your owners manual. It should be about 5.5 quarts.
Don't overfill. ... :thumbup:
Tip: Check your oil with a white paper towel.
..... Don't overfill. ... :thumbup:
Owners manual says 5.2 quarts. I can't tell on dipstick if it's full or not.
Just check the oil level as per the recommended procedure, only when you pull the dipstick out, simply place it on that white paper towel - the contrast between the 'wet' oil level and the 'dry' dipstick above it should be a lot easier to see! :thumbup:
Anything over 5 quarts will be within the range markings. If you take the dipstick, abrade it lightly where the range markings are, then wipe down and apply black or red Sharpie ink, seeing the clean oil becomes easier.
