How to gear up to ride comfortably and safely in really hot weather?
UtahPete
Well-known member
Originally Posted by Pirate looks at --
Great post Ann. People don't understand the laws of Thermodynamics. Heat will always try to find a balance and transfer from the warmer surface to the cooler surface. If it is over 99 degrees outside, you want to keep your 98.6 inside and away from the 102 outside. You will remain cooler by zipping up all vents and even closing the vents on your helmet. Keep the 98.6 inside and you will be cooler. I tested this coming home from Valcourt. Drove 200 miles across South Dakota in 102 degrees. I closed up everything and remained cool throughout. Once you jump out there in your shorts you will dehydrate and go into heat sickness very fast. So if you are going to the grocery store you can wear what you want, but for me, I am going to remain covered like those cool, calm collected BMW ryders.....and the long, tall cool one....Ann Myers!
I'd sure like to pursue this topic a little more. My wife and I took a ride yesterday in 96 degree weather. She was wearing her First Gear Hypertex jacket and I was wearing my mid-weight Olympia jacket with the pocket vents open. We both have HJC IS MAX-II modular helmets with the vents open. I was pretty warm but not dangerously uncomfortable but Jane was miserably hot.
So, I'm looking into this again, because living in Utah, hot weather riding is a reality and for safety sake if nothing else it's important that we not get overheated when riding.
So, vents open or closed?
Dedicated hot-weather mesh jackets or not?
High tech evaporative vests with built-in water supply worth the money and bulk?
Thanks.
hot weather riding
My wife and I use full mesh jackets with armor in the key areas, and combine that with cooling vests, which are a quilted vest that is made to soak up a lot of water. We have ridden in 100+ degree weather for hours at a time and kept cool enough to keep riding. or last big ride of 2,600 miles in nine days found us in Hell's Canyon at 104 degrees and we managed alright. I don't enjoy riding in that kind of temperatures but with the cooling vest we can. They last about two hours until we need to re-soak them down.
We do have those cooling vests and just haven't used them for some time. Thanks for the reminder.
I have the Dainese City Guard mesh.. great jacket.... looking at a Fly cooling vest .. any other vendor recommendations for a cooling vest?
This is a DANGEROUS misconception to be passing around.
The human body MUST have some way to shed heat.
IF you enclose yourself with no ventilation, your body's temperature will continue to rise until you have a heat stroke.
But you don't have to believe me: ASK A DOCTOR.
Just because you saw it on the Internet and it SOUNDS plausible does not mean that it is true.
This is a DANGEROUS misconception to be passing around. The human body MUST have some way to shed heat. IF you enclose yourself with no ventilation, your body's temperature will continue to rise until you have a heat stroke. But you don't have to believe me: ASK A DOCTOR. Just because you saw it on the Internet and it SOUNDS plausible does not mean that it is true.
I didn't 'see it on the internet'; I saw it here on this forum by an experienced and respected member of the forum.
What do you suggest is the best way to go about keeping cool and safe in very hot weather?
I said basically the same thing before. You need some airflow across your body to assist with evaporation to help cool you. But, too much airflow could cause problems; you need to make sure you stay hydrated, and not become dehydrated; this is especially so in warmer climates where the temps are above body temperature.
Without getting into a whizzing contest, this time I find myself agreeing with Easy Rider.
My thoughts
Vents open or closed. Depends on how hot it is. At 96 degrees the outside temperature is still cooler than your body temperature so in that case vents open and or mesh jacket and a cooling vest is really great to have. This is what we use https://www.revzilla.com/motorcycle/revit-liquid-cooling-vest. I do find that it lasts longer if I don't wear the mesh jacket, but use my 4 season Jacket with vents open. Either way you can recharge them when you stop to get gas by soaking them again.
This summer we have done a lot of ryding in 105 to 106 degrees. Now science tell us that heat will always transfer from the hotter surface to the cooler surface. The laws of equilibrium tell us that if it is 106 outside and you are at 98.6, you want to keep that hot air out. This is where you would want to close vents (and yes even in your helmet) and keep the cooler 98.6 on the inside and the 106 on the outside. You will sweat, but that sweat will last longer and cool you longer if you can keep it from evaporating too quickly. You will still receive some benefit from the cooling vest in these conditions. A couple of reasons why the heat has a greater effect on your wife would be that she is probably smaller than you, so less surface area for the sweat to cool her, and her pores are smaller than yours and she just doesn't sweat as efficiently as you do. I have ryden in 106 for 4 hours completely closed up and kept pretty cool. Certainly I had no symptoms of heat sickness at all. Oh and drink at least a liter of water ( and only water ) for every hour on the road.
So key temperature is 99 degrees, below that temp open up ( but keep fully covered no tank tops, flip flops, cutoffs etc. Above 99 close up and lock in that cool 98.6. BTW if you are just taking a quick jaunt to the grocery store.........wear whatever you want!
Sounds logical, but if the air that is flowing over your body is at 100 degrees or more, your body temperature will rise as well, plus you will have an increased evaporation of sweat, and more quickly become dehydrated.
Vents open or closed. Depends on how hot it is. At 96 degrees the outside temperature is still cooler than your body temperature so in that case vents open and or mesh jacket and a cooling vest is really great to have. This is what we use https://www.revzilla.com/motorcycle/revit-liquid-cooling-vest. I do find that it lasts longer if I don't wear the mesh jacket, but use my 4 season Jacket with vents open. Either way you can recharge them when you stop to get gas by soaking them again. So key temperature is 99 degrees, below that temp open up ( but keep fully covered no tank tops, flip flops, cutoffs etc. Above 99 close up and lock in that cool 98.6. BTW if you are just taking a quick jaunt to the grocery store.........wear whatever you want!
Okay, so it sounds like a cooling vest is in order either way?
Yep
Totally agree. You can get the same type of material for your neck and wrists. These are two areas of the body that have a lot f blood flow close to the surface and allow S for cooling of the blood stream.
I forgot to add to my original reply that along with the mesh jacket and cooling vest we do stop and drink a lot of water. occasionally we drink a small bottle of power aide but mostly water. on our trip to Glacier Park last month on our way from Portland to Boise we rode in over the high 90's and arrived in Boise at 104 that night. We made many stops along the way to hydrate and rest.
Evaporation is what causes your body to cool, and I also said to be careful of too much air flow. The higher the humidity, the slower the evaporation process. Just because the outdoor temp is warmer doesn't mean the evaporation process from your skin stops, the higher humidity will slow it down more. Also, what will help with high humidity is movement of air across your skin which helps the evaporation process; it's helping to blow that high temp/humidity away from your body; so, don't stop moving, and stay hydrated.
That's a good point. What works in an arid heat like out west may not be the best solution for high humidity climates like east of the Rockies almost anywhere. In the latter case, would you say skip the cooling vest and let the breeze through the mesh jacket do the cooling?
I'm sorry. I'm done. This is the point where you'll have to try things for yourself. I shouldn't have come back on here. I've finally decided to make the plunge. Adios.
You need:
Airflow
Protection from the Sun's rays
LOTS oi water
We use our mesh jackets (with full armor), modular helmets, gloves, and boots.
We also hydrate before, during, and after the ride.
Boom-chacka-lacka! :ohyea:
This keeps us riding even when the temperatures get really deep into the nineties! :thumbup:
(It rarely scratches 100 around here!)
Have ridden many times in 105 - 112 degree heat in TX/AZ. Mesh is your friend. Also, use cooling shirts/vests/pants under your mesh. I've actually gotten pretty cool in these conditions. If you don't have the cooling gear.... soak the long sleeve shirts and pants in water and wring them out. Best cooling I've had for a few hours under mesh.
Was wearing mesh in a bad crash last year. Didn't get a scratch on me!!
Have ridden many times in 105 - 112 degree heat in TX/AZ. Mesh is your friend. Also, use cooling shirts/vests/pants under your mesh. I've actually gotten pretty cool in these conditions. If you don't have the cooling gear.... soak the long sleeve shirts and pants in water and wring them out. Best cooling I've had for a few hours under mesh. Was wearing mesh in a bad crash last year. Didn't get a scratch on me!!
Good feedback. Thanks.
