FalconAF
OK, I've been away for a while and was catching up on the forum posts. I ran across this thread. And I'm probably gonna p*ss some people off here with "my" reply to it. But...
There is a LOT of VERY BAD and DANGEROUS information being passed on in this thread. For instance, ANY reference to your CORE BODY TEMPERATURE of 98.6 degrees being "The Temperature" you need to be concerned about as far as the OUTSIDE AIR TEMPERATURE is concerned is completely false. It's your SKIN temperature of 93 degrees that matters. Any outside air that is passing over you SKIN that is warmer than your SKIN temperature will cause an increase in your core body temperature. So, you need to be doing proper cooling beginning at an outside air temperature of 93 degrees...NOT 98.6.
Mesh is NOT the SAFE solution in cases when the outside air temperature exceeds 93 degrees. The amount of air it allows to pass over your body will cause you to "sweat out" in a ridiculously short period of time. And even if you use soaked wicking materials under the mesh, they will dry out exceptionally fast. And in many cases, you would NOT be able to consume enough fluids during that time to compensate your body fluid loss without risking OTHER dangers that could quickly kill you too. Do a Google search for "hyponatremia" if you want to see one (more commonly referred to as "water poisoning"). What you want to do is NOT wear mesh, but STILL use cooling techniques that will create a SEPARATE ENVIRONMENT INSIDE a MOSTLY CLOSED riding jacket or full body suit. You open a SMALL vent on the jacket/suit that will allow JUST ENOUGH air inside the suit to maintain an evaporative cooling environment INSIDE THE SUIT, and you don't want to have that environment immediately tossed out the back of the suit through large open vents. You regulate the interior environment by having just enough incoming air/exit vent air volume to keep the cooler air inside the suit as long as possible and replaced in a timely manner with new incoming air. When this is done in combination with something like an LD Comfort LONG SLEEVE wicking shirt, the result is the water on the shirt lasts a LOT LONGER time before evaporating, and it significantly REDUCES the amount of your OWN body moisture from sweating out of you. This also significantly reduces the amount of fluid INTAKE you must "drink" to replace your own sweated-out body fluid. A full mesh covering (jacket or full length suit) will just WASTE the cool air you create underneath it when it immediately gets vented away again from your body. In a nutshell, you want to create the equivalent of the inside of an astronaut's space suit that will maintain a separate cooler environment inside the suit.
Here is the SCIENCE of it.
http://www.ironbutt.com/ibmagazine/ironbutt_1002_62-66_hot.pdf
It was written long ago by a medical doctor who is/was also a long distance rider. It works. I used (and was taught) the same techniques in advanced survival training during my 26 years in the military (there's a reason the first thing you should do when in an environment over 93F degrees is COVER YOUR EXPOSED SKIN to prevent the higher temperature ambient air from blowing over it...it's the same reason you see people living in the Middle East, etc, wearing full length robes when outside in 100+ degree temps). I routinely ride in Las Vegas, Nevada, and the desert southwest during the summer wearing a full length Roadcrafter Aerostich suit using the methods explained in the article, and can do it in temperatures ABOVE 110F. I have done it in temps as high as 116F riding through Baker, CA on I-15 at Interstate speeds of 75+ MPH. I also have over 90,000 motorcycle miles riding all over the U.S. in much higher humidity areas like Florida and the Gulf Coast in high summer temps. It works there too. Yes, the cooling effect will not be as great as in low humidity areas like the desert southwest, but it DOES STILL WORK. Mesh can get you killed trying that if you get "behind the power curve" and dehydrate yourself to a critical point before you realize it is happening.
Please...PLEASE...do not confuse OPINIONS with FACTS. The science does NOT lie about topics like this. People are entitled to their own opinions, but they are NOT entitled to their own facts. Do not teach opinions as facts, especially when untrue information could get someone killed. Please read the article and understand the very dangerous risks of using mesh riding gear above 93F.
Respectfully submitted. And if you don't agree with any of it, that's fine too. Just please quit teaching opinions as factual information when it isn't. People's lives may be at stake.
