Don’t know if this option would work for you. If not, perhaps someone else? Purchased from LaMonster. Actually, LaMont’s wife suggested this mount for my phone, Spyder (21’ RT Limited)
You can see the tools I used to mount this rig lying on the pillion. FWIW, I don't have many miles on this Spyder currently (4500) yet i have ridden on some rough, washboard roads at times & its held up with nary a hiccup. Note that anyone asked but i use the phone mounted like this to listen to music primarily via Bluetooth earbuds (Apple brand)
If the phone’s batt is low I’ll plug into the harness found in this cubby hole (hot only w/the motor running)
I was making a half dozen runs up to Jacksonville this past spring, and the main reason I acquired the mount in the first place, so I could follow mapping to get up to Clear Choice (In JAX). Surprisingly, using the GPS on the cheesy iphone in the pics, I could hear the voice prompts that came through the mapping program whilst listening to the 6 speaker stereo that came standard on this RTL edition quite easily despite cranking the volume to listen to loud rock blasting thru the Jacksonville freeways @ (80 + MPH)
I normally wear a 1/2 helmet
The helmet in the above pic. Wether its voice prompts via the iPhone’s GPS or music coming through You Tube on the iphone, the Apple earbuds I’m using (1st gen), and they’re Apple earbuds I bought used from Amazon, I can hear music or plain speech quite well with the kit i mentioned. Again, it”s all low budget components yet I can hear it all clearly at speed wearing a half helmet, which isn’t”t the quiet atmosphere i have while wearing a full face helmet
Best,
Jake
Reddick Fla.
An appointment is an engagement to see someone, while a morningstar is a large lump of metal used for viciously crushing skulls. It is important not to confuse the two
