I admit defeat - I now understand how dealers might charge $7-800.00 for a spark plug change!
IGETAROUND
Well-known member
I now understand how dealers might charge $7-800.00 for a spark plug change. I have well past 20 hours invested and I didn't get past the air box!!! I have started reassembly and went on to antifreeze renewal. Then I will be able to complete reassembly and move on to the brake pads, brake fluid flush, and antifreeze renewal on my wife's RT. Oh, and does anyone know where I can get a parking brake return spring? It seems I have misplaced one. I hope the rest of you are enjoying your winter maintenance as much as I am! :LOL::ROFLMAO: That's my story and I'm sticking to it!!
Al in Kazoo
Al in Kazoo
Even though I used to do my maintenance on my cars and trucks, I find that now I can take those same hours and work to make the money to have a professional do it. I still like the satisfaction of doing some things myself, but the hardest part can be finding someone who you can trust to actually work on your vehicles and do it right.
Good luck putting it back together. I saw you mentioned a missing spring. My problem used to be that I would get it back together and have a few extra parts left over. I have a drawer for those.
Al in Kazoo
Next time, take a short spin down to sunny Tennessee where we'll do your plugs, sonic clean your injectors, and shake your hand for less than $540.00. And almost 10% of that is sales tax!
I had the dealer do the 30k service (plugs incl.) after 5+ years of never being back since purchase. I'm 79 and I do all the regular maintenance and tires but saw the plugs as a challenge I didn't want to attempt. I paid $1000 for the service ($250 parts, $720 labor). So, I rationalized that as a $200/yr old-guy tax. If I'm still here in 5 yrs, I'll gladly pay again.
It is a tough one! The whole thing is a series of taking off an unrelated component to get the piece you need off of the machine then rinse and repeat... I have done it once and that is enough for me!
I truly believe that BRP likes to make work real work. Especially when it comes to normal maintenance. You know changing your sparkplugs, replacing your air filter and transmission filter. Hey even changing your engine oil and filter are a little bit of a challenge.
I am sure BRP is saying that if you can afford a Spyder, you can enjoy paying for the maintenance.
Just the way I feel sometimes.
Now I got that out of the way.
I can ryde down the road to adventure.
Have a Blessed Day. (y)
When having the transmission output shaft recall done, if you are anywhere near the 30K mark, have them install plugs while the engine is out.
When I did the plugs in my 2012, I thank God I got the air box delete kit from Ron, wow was it worth getting rid of that thing!!! You had all kinds of room to play under the hood after that, I could almost have put another half a motor more under there! When I need plugs in the 2025 it will be down to Ron's shop!!! :cool:
I did exactly that last March.
Had the technician change the fuel filter also.
Here's a photo of how dismantled my F3L was during surgery for the output shaft recall.
In the upper right of photo, the engine is sitting on a shop bench.
I got to keep the shaft too.
This only had around 12K when the recall was done. And my Washington Spyder has only 4100 miles and gets the recall done in June.
I took mine in and it's having the output shaft work done, today actually. I provided the oil and coolant (Amsoil) and gave them the spark plugs to replace while the engine is out of the bike, because I read up on changing those out as it sounded like a bearcat for sure. We talked about changing out the thermostat as well, but I guess it is part of the water pump assembly and the service manager said, hey if its not broken, let's not mess with it, so I agreed. Front sprocket work is already done, so it'll be good to have all the warranty work done and bike back.
