I Designed & built a camper to pull with my Spyder...
Cavman
I designed and built a camper that I can pull with my Spyder. It’s on a Harbor Freight trailer. The camper part is made with 6061 T6 aluminum sheet, angle, and channel.
Looks like good work from what I can tell! I wonder what kind of MPG you'll get towing a "box" though. Also, afraid of all that metal cooking you if you're going to try to sleep in it.
I gave it a trial run with my car a couple of weeks ago to AZ. Only a couple mpg less pulling it. I have an Icy Breeze on order. A replacement solar vent fan arrives today. It’s rated to pull 1000 cu ft of air a hour. I have a silver tarp and poles to setup over the camper in hot weather.
I’m taking it to the local dump today to get it weighed. I’ll post the results later.
Looks like you did a good job putting it together but I would be concerned about the wind resistance and how a cross wind would affect handling of the trailer and the Spyder?
I had that HF trailer for over 10 years before giving it to my son in-law. Excellent value for the money.
I took it to a truck stop and got it weighed on their Cat Scales. Shows up as 360#. After taking it AZ last year I got a mattress cover for it so I could move around inside better.
It’s built on a Harbor Freight trailer. The frame and aluminum sheet came from Online Metals. 6061-T6 .040. Back piece is .062.
Held together with stainless steel 1/4-20 hexhead screws and lock nuts.
"Air Scream" made me smile. :D
