bscrive
I finally got the bars on Friday and I had a chance to put them on today. It was a straight forward process and the only thing I had to do was widen the bottom screw holes on the plastic collar so the screws will fit. They took me about six hours to complete, but I have had the tupperware off several times. I did put on RT bars a few weeks ago to make sure that they would fit. This is not a hard job to do. The hardest part was putting the little bolts, they give you, in to hold the plastic collar on. I used tape wrapped around the socket and the head of the bolt to hold it in the socket to screw it in. This way, when I felt the bolt taking hold, I could pull the socket off the bolt and put on the next one.
I did have to adjust the bars up a bit because they would hit the parking break when I would turn the handle bars all the way to the left.
Here is a picture of the finished product.
I also put on aftermarket fog lights
and pink under lighting on the bike as well as pink graphics with reflective borders.
I am still waiting on the rocker switches to complete the lighting.
The other thing I put on is an Utopia backrest. It came out looking great and Deb just loves it. :yes:
I am still waiting for a 150db air horn to come in and I am going to install that on the right side of the bike under the tupperware. I found a completely metal one so that it won't melt it with the heat in there.
